montage autoradio gps androide 10.25p
biff31
Voiture : E70 xdrive 2013 3.0d 245
Re: montage autoradio gps androide 10.25p
Message par biff31 »
Install Android app (APK) files from SD card or USB Flash drive.
To install an Android app (APK) on the head unit copy your APK file to your sd card or USB Flash drive. Insert the sd card into either slot of the head unit or plug your USB Flash drive into any of the USB ports then open the app named "ES File Explorer". Use the file manager app to locate your APK file on your sd card or USB Flash drive. Select the APK file you would like to install and that will start the install process.
You can set the monitor to remember which UI menu to boot into each time your car starts.
To set the monitor to boot into the Android Menu UI:
1. Open the Music Player
2. Now turn off the car and wait 45 seconds.
3. Turn the car back on and the monitor will remember to boot back into the Android menu each time.
To set the monitor to boot into the original BMW iDrive Menu UI:
1. Switch to the original iDrive menu any screen will be ok.
3. Turn the car back on and the monitor will remember to boot back into the original BMW iDrive Menu UI.
biff31
Download the Android app for the USB TPMS Kit.
https://drive.google.com/file/d/0B5csZB ... sp=sharing
biff31
DAB+ USB Dongle
Download DAB app
https://drive.google.com/file/d/16sekgP ... usp=sharin
1. Download and install the DAB Android app.
2. Plug in the USB hub into the monitors USB port.
3. Plug the DAB USB dongle into the USB hub. (This step is important. Do not skip this step. The DAB dongle will not work without doing this)
4. Open DAB Android app
If you need any help that is not already included here you can email us with your order number at support@avinusa.com
Please provide as many details photos of the connection that you have already made. Close-up photos of the part or wires that you have questions or need help with. Make sure the photos are clear and specific to your questions. This will help a lot in determining where the issue might be.
List each question by number so it's easier for us to reply to each question. Also, list the steps you have already tried to fix the issue. This way we can provide a solution faster.
1. Question 1
2. Question 2
3. Question 3
fabricio
Voiture : X5 30D E70 PACK M
Message par fabricio »
Merci Biff 31 c'est très intéréssant!! :Top: :Top: :Top:
biff31
Désolé en anglais , mais pas trop compliqué à suivre .
J'imagine que c'est pour tous pareil même si c'est pas du Avin.
De toute façon avin usa ce n'est que de nom , le mien arrivé direct de Chine et pas des states :evil:
fabricio
T'inquietes pour l'anglais je vais me débrouiller.. ;)
Tu as raison ils sont tous fabriqué au même endroit, mais au niveau SAV AVIN et 4x4 SHOP c'est mieux!!
J'ai démonté le mien pour le renvoyer car j'ai bien un blême..ça m'a fais mal au coeur de remettre l'ancien écran mais ce n'est que provisoire, le temps
qu'ils m'en renvoie un autre.
biff31
Bonjour a tous
Quelqu'un d'entre vous c'est équipé d'un antenne Dab+ ?
Le système à l'air peu développé encore a ce jour .
Si d'autre ont testés , merci de vos retour .
Dernière modification par biff31 le 19 déc. 2018, 17:36, modifié 1 fois.
Je ne pense pas que le Dab+ soit déployé en France, la radio reste en analogique.
biff31
Je me suis lancé en me fiant au site internet Français qui déclaraient un développement depuis 2014 ..... Pas tant que cela pour l'instant
z
zimbolodejaz
Voiture : (E70) XDRIVE30DA 235 LUXE 7PL
Message par zimbolodejaz »
biff31 a écrit : 04 sept. 2018, 08:05
Non le plus galère c'est de remettre en place la partie radio avec le gros connecteur iso.
Pour le câble "aux" suffit de le faire longer sous le carter latéral droit de la console centrale.
Le mien un 2013 , sans brancher le câble "aux" ça marche pas .
Moi j'avais aussi pris le y pour câble "aux" mais pas utilisé, le son était vraiment dégradé avec . Si besoin de conseil hésité pas .
Pour la cartographie , j'avais pris la version vendu par Avin pour l'Europe, mais pas de choix pour la langue du guidage vocal, Anglais ou Américain seulement , se font pas ch... pour 50€ la carte !
Du coup j'ai mis la carto "sygic" en version full , elle est vraiment très bien .
[/quot
Bonjour Biff31,
Je suis intéresse par ton SYGIC peux-tu stp me donner des tuyaux?
Je fonctionne en ce moment avec waze mais ça me saoule le partage de connexion à chaque fois.
merci par avance
biff31
Hello
téléchargé sur Google Play. .
Je fais le point demain et reviens .
A+
biff31
fabricio a écrit : 16 sept. 2018, 21:14
Des news ?
Dernière modification par biff31 le 11 déc. 2018, 18:44, modifié 1 fois.
fabricio
A mince toi aussi, moi qui croyais être un cas isolé! J'attends que 4X4 shop me renvois un autre appareil mais ils ont rien trouvé sur l'ancien malgré un
essai chez eux de plu d'une semaine.Je verrais bien en remontant le nouveau..
Tiens nous au jus!!
fabricio
Au début le mien s'est mis a me mettre no signal au bout de deux heures de fonctionnement et je ne pouvais rallumé l'écran que par le bouton menu sous l'drive et n'avoir que les fonctions d'origine.J'ai donc essayer de défaire les connexions pour voir si c'étais un mauvais contact d'une broche et bien c'étais pire ensuite, ou plutôt bizarre..Parfois un on off avec le contact été suffisant pour le relancer..Je pense a une rupture d'alimentation interne de l'écran comme ça faisais sur les tours d'ancien ordi quand tu allumé l'écran avant la tour il y avais le même message(no signal)Donc je pense aux connecteurs qui sont pas de très bonne qualité faut reconnaitre surtout au niveau de l'écran (le blanc)et qui coupe l'alimentation de quelques fonctions.
Ce n'est que mon analyse, je ne suis pas électronicien juste électromécanicien mais je peux quand même te dire avec certitude qu'il ne faut pas grand chose pour perturber les petites tensions.
Il y a peut être eu une mauvaise série et on est dedans.!Car il faut pas se leurrer ils viennent du même endroit..!!
biff31
Pour ceux qui on mis un Android 7.1 , vous devriez installer une appli pour vérifier que vous n'ayez pas une version fake. ... semblerait que il y est plus de faux en vente que de réelle version 7.1
Certain vendeur sérieux comme 4x4 shop au Canada prévient ces client , eux n'ont jamais commercialisé cette version très instable , surchauffe et d'énorme bug , il proposent la version 4.4 ou 8.1
Dernière modification par biff31 le 11 déc. 2018, 18:45, modifié 1 fois.
LeFaf31
Voiture : BMW X5 (E70) LCI 30d Exclusive
Message par LeFaf31 »
biff31 a écrit : 30 nov. 2018, 11:16
Seule proposition d'avinusa , retourner à mes frais le produit (de France plus de 60€) et après analyse peut être le renvoi d'un autre appareil ( Donc avec risque d'avoir la même chose au bout de 3 mois) et si renvois d'un neuf re paiement des frais de Douanes .
Donc plus de 120€ de ma poche pour du matériel sous garantie , un poil honteux .
Je comprends qu'entre le moment où je l'ai acheté et à se jour le prix est baissé de quasi 50% .....
Je n'ai pas tout suivi, mais normalement tu ne payes pas de frais de douanes sur un renvoi d'appareil suite à une prise sous garantie ;)
biff31
C'est aussi se que je pensais :study:
franck c
Voiture : x5 E70 40d de 2010
Message par franck c »
bonjour comment peut on avoir la dernière mise a jour de l'android en 4.1 . j'ai demandé chez avinusa mais mon android ne vient pas de chez eux donc ils disent non. J'ai proposé de payer mais nada.
si quelqu'un peut m'aider.
Eraaz
Voiture : M140i xDrive
Message par Eraaz »
En gros biff tu ne conseil pas Avinusa ?
biff31
:NonNon:
Dernière modification par biff31 le 11 déc. 2018, 18:46, modifié 1 fois.
